Hi all
was wondering if someone could share their technical know how on a pedal I’ve got that’s playing up.
I have a greer Burning Goat that I bought second hand a few months ago. I had it connected up to an MS3 for a few months with no issues but I’ve since moved on from that and am now running my pedals individually connected to a walrus Phoenix power supply. The burning goat has since developed an issue , in that it cuts all the signal when I turn it off and then gradually brings it back. I can’t afford / it’s not worth sending it to the states for a diagnosis so just wondering if this rings a bell with anyone on here or if anyone has suggestions for someone I could send it to for a fix
all the best and Happy new Year to everyone
I haven't seen the insides of a Burning Goat, but if it uses the same switch as the Lightspeed, then it's one of those blue 3PDT jobs with nine solder tags. If so, it should be relatively easy to swap out, if you can solder.
