Ok, obviously I have a load of stuff already, but for the purposes of this assume I have zero gear other than an ipad and electric & acoustic guitars.
If I wanted to be able to play out in a duo with 2x singers and 1x guitar, using some form of looper (laptop, ipad, pedal solutions all valid), and employ some sort of drums/bass/synth sounds somehow... what's the best option? For context, this would be for playing pop/soul covers in bars and events, so I don't need screaming 4x12s etc. But I would definitely want a pretty comprehensive looper, not just a single-loop gizmo with a couple of buttons
I figure I have a number of options, potentially in combination....
iPad with Loopy Pro (would need foot control as well - maybe with a Helix of some sort)
iPad running Bias FX or similar
Laptop running Ableton
Some sort of looper from Boss ?
Aeros
Helix
Headrush Looperboard
Am I missing anything? What do you use? What would you use?
There are 16 pads onto each of which you can record a loop, although once recorded you can't overdub. You can also pre-load your own samples onto any of the pads and sequence them for drums/bass/synth and/or hook up a midi keyboard to play them live. They go for around £400ish used, although you'd probably also need to factor in the cost of a midi foot switch for live use.
I have found it brilliant for quantized looping of electric/acoustic guitars/bass and synth at home, plus it's tiny and runs off a USB battery pack so easily portable as well.
I used to do a bit of looping and having dedicated stop start footswitches for each channel is a must in my opinion. I also think hands free is the best way to go.
The boss also has a decent i/o selections, so adding in guitar, both vocals, maybe a synth would be easy and it has onboard drum possibilities.
1. I would avoid ipad solutions as too flakey for anything more than playing backing tracks. I have tried them at home and there is plenty of faffing about.
2. I had a few loopers before I got the Aeros. It's miles better than anything else I've tried (although to be fair the boss RC-600 looks impressive) and Aeros does get some complaints/niggles in their forum from people who actually perform.
3. Drums from beatbuddy. The sync between that and the looper works very well, but doesn't work so well with other loopers (it can work with faffing)
4. I would go for a modern multi-fx for other sounds i.e. octaver for bass sounds and there's always some kind of synth pad style reverb in there. If you get a fancy one (quad cortex?) you can also route vocals through it for reverb/delay on that.
5. I would tend to want to control it all via one midi controller e.g. morningstar. remembering the workflow for different boxes while performing would seem tricky to me.
edit: 6. you could also preload loops with synth/bass tracks on to simplify the workflow.
You will need a mixer if you're including vocals and it's all going into one PA. Although now I've mentioned the quad cortex you could maybe put it all through that.
https://www.instagram.com/insta.guitarstuff/
Having watched a good bunch of KT Tunstall vids though I am v keen on some sort of drum machine/groovebox
And the singer saw Ed Sheeran at the weekend so I'm guessing she'll be super inspired so need to get on with it!
What I do now know is we definitely want to be able to loop:
- At least 1 vocal, probably 2
- Drums from a small drum machine. Most likely played live then looped,
- Electric guitar
In the long run electric and/or acoustic and/or keys would be nice, but not all at once, so that could be dealt with via an external switcher/mixer if needed.I don't think the Aeros has anywhere near the I/O we'd need for that lot, RC600 could probably do it but I'm not sure I like the workflow as much.
Has anyone tried a Sheeran Looper yet...?
