A few spring to mind:
Eventide Rose - 50 second delay
Meris LVX - 5 second delay
HX Stomp or HX One - (8 second delay) this does loops which fade out with each repeat so double good.
Strymon El Capistan and Volante - SOS looping mode
Chase Bliss Habit - 60 second delay
Soma Cosmos - weird multiple long delays
DD-500 I think
Empress Echosystem - 10 second delay
TC Flashback - 8 second delay I think , plus Triple delay has three lots of this.
Eventide Ultratap - 10 second delay
Yes, it'll do up to 10 seconds. A couple of the modes have shorter maximum times.
And that's for the reissue which is supposedly different enough from the original as to be not worth bothering about.
Doing it the old way then pretty much any delay with expression pedal support will work.
Or use a volume pedal and a mixer- Gigrig do some useful products, like the Wetter Box that might help.
Fripp uses Eventide processors now.
H3000 and H8000 from memory (is that a pun? If so I want credit).
It will be difficult to get that sort of functionality out of a pedal, but the H90 will be the closest.
It isn't really the delay that matters, it is how you construct the signal path of multiple delays, in series/parallel, feeding one into the other and such.
I'm not looking to nail Fripp's thing, but rather use it as a starting point for my own thing.
Fractal products do a great job for me.
I have a number of FM9 patches that give me unpredictable results that require me to respond in the moment to avoid a car crash.
The pedal that I love the most is Hexe Revolver DX.
It might not have the right delay time for you, but I've got it set up as a momentary capture, so any line I play can be captured, reversed and played back with a fade out over time, which is adjustable.
But yes, Chords of Orion is a good source to look at a version of Frippertronics..
