It’s identical in sound and has the benefit of a level control too.
I have a 30 year old CE-2 and the Mooer is bang on.
you need
https://i.imgur.com/4FtdBKN.jpg
If you could actually hear that much of a difference, and especially at a live gig, it'd be worth the extra money, but since you can't, that is why I have a UC-200 on my pedal board.
I'm about 90% certain its the same as the CE-2, only with a clean blend. But it can be had for a fraction of the cost of a CE-2 because it is ugly and brown, not shiny and blue.
If it's just gonna be used on one or two covers at a gig, there's little point in spending a lot on a Boss when the Behringer will do the trick for peanuts. I know they cop for a bit of flak for having ABS cases, but I've never had one of those break - ABS plastic is actually incredibly strong - so I don't see the problem with that unless you wear motorcyle boots and jump on your pedals when gigging.
Curently using a DC-2 Waza but the Boss Super Chorus CH-1 I had was doing a more than adequate job.
To be honest live... no one's really going to know (or care) what chorus pedal you are using in the wash of sound...
I'm probably going to buy a Mooer Ensemble King, as it will fit on my board more easily than a Boss-sized pedal and it's cheap.
The CE-5 is probably even less and is close enough for most purposes. The CH-1 is a bit different, but still a ‘Boss Chorus sound’.
Light turns on but no effect comes out with the dials in any position.
It also won the Andertons blind Chorus shootout which suggests there is something in it.
That said in a pub you probably won't appreciate the difference, but it's a pedal that's never come off my board and I don't regret splashing out on for one second.
