FS price reductions - Ibanez AF-2 Flanger £110 -Ditto £45-Canyon Delay £80 Gearbox £160
SpaceaceukSpaceaceuk Frets: 18
edited April 13 in FX £
Having a big clearout having just slimmed down my board and to fund some future purchases i have in mind. All prices include p&p in the uk .Most of these do have velcro on the back and are in good condition unless stated otherwise.
Open To Offers!
TC Electronic Ditto - £50 now £45 now £40
pictures to come but in good condition with instructions and box .
Ibanez AF2 Flanger Paul Gilbert - £130 now £125 now £110
A really unique flanger from the mind of Paul Gilbert with a grat shapable sound and the unique takeoff mode that gives you sweeping dive bomb and siren sounds for a really unique take on the classic flange. This is an older pedal and has been used regularly, as such there are some chips in the paint as can be seen on the picture, the pedal itself works fantastically though. No Box
Bright Onion ABY Pedal - £25
ABY Pedal that will slect output to either A/B or to both A+B. No Box
EHX Canyon Digital Delay - £95 now £90 now £80
Quite brilliant multi delay pedal with 11 different modes including a looper, shimmer, octave, delay, tape, reverse and many more. Ive switched to an ibanez analog delay because honestly there were more features than i knew whatt to do with but this will make an excellent delay for anyone.No Box
Catalinbread Dirty Little Secret - £85 now £70
Awesome Plexi sound with internal switch to swap between Super Lead and Super Bass. No Box
Mooer Trelicopter - £35 now £30
Fantastic simple tremolo peadal in a small footprint. With Box
Wampler Gearbox - £165 now £160
Andy Timmons signature overdreive pedal which has the amazing Wampler Tumnus on one side and the fantastic brown sound Pinnacle pedal on the other. Has a built in noise gate for the pinnacle side and the ability to choose which way the pedals stack with each other. Brilliant pedal. Comes with box
MXR Smartgate - £70 now £65
With 3 selectable modes of noise reduction this is possibly the simplest noisegate to use and does a fantastic job. Comes with box.
Carl Martin Octaswitch Mkii 8 Input Loop Switcher - £150 -  now £125
An Excellent loop switcher using dip switches to select what each bank plays, 8 inputs and 8 settable banks. The Buffer Circuit has burned out on this but it is still fully useable as a pedal, i emailed Carl martin directly about it and they said "No you’re not doing anything wrong, it’s the buffer circuit burned.However if you always have a loop with one or more pedals engaged, you don’t need the buffer is the pedals are." As i say still perfectly useable and a massive help if your constantly tap dancing between songs, price reflects buffer circuit issue. Comes with box
Tone City Summer Orange Phase - £35 now £ 28 now £20
Simple Mini size Phase pedal with box great for compact setups
Landlord FX Cheeky Pint Compressor - £25 now £20
Simple Mini size Compressor with box great for compact setups
Tate Fx Germanium Rangemaster - £65 now £60 now £55
A one off build using only the best of the best components and point to point wiring , came without a box.
NUX Optima Air IR - £100 now £95 now £90
Brilliant acoustic guitar simulator for both electro-acoustics and electric guitars using Impulse response samples of some legendary acoustics, you can even download user made IR files and create your own. Excellent for making Piezo based electro acoustics sound great and for that one acoustic number the electric guitarist needs to play in the set. Comes with box
TC Electronic Mimiq Mini - £40 now £35 now £28
Superb little doubler pedal you can get some neat sounds out of , not to be confused with its big stereo capable brother. Comes with Box
SOLD LIST
Keeley Compressor Plus  - £75.
ProCo Rat 2 - £65
Nobels ODR-1BC - £65
Pigtronix Octava Micro Octave Fuzz - £70
Earthquaker Devices Bit Commander - £110
MXR 6 Band EQ - £60
TC Electronic Spark Boost - £40
Digitech Drop - £100 TRADed!!!
TC Electronic Skysurfer Reverb - £35 sold
Moen Shakey Jimi - £35 now £30 SOLD
Maxon OD-9 - £75 now £70 SOLD
Cheers
Joe
