The only quirky thing - and it's very much dependant on your setup, though I've read this in other places - is that the tone controls need to be placed in extreme settings. E.g. I have the bass control nearly off, and the treble turned up just past 3 o'Clock. Things at 12 make it really woofy, but maybe that's just like the old Silvertone amps?
You have to set the knobs with what your ears tell you sounds right and not what looks right - they are quite woolly woofy amps in general I think so in that respect it's accurate, but you can get clearer sounds from it.
Bear in mind that Jack White always uses it alongside a Twin reverb (or other Fender amp) so his sound is not necessarily the Silvertone sound by itself, but rather it's half of the blend.
If you seek out the Third Man Double Down pedal demo video on Youtube with him playing through it, you'll hear what each of the two amps is doing when they show the two outputs of that pedal separately (best with headphones!).
But it certainly has that kind of vibe to it and very usable pedal.
soundcloud.com/thecolourbox-1
