I have a Japanese Fender Strat from the early 00's. I've heard over the years comments that the electrics in Japanese Fender guitars are bad. Most recently from a guest on That Pedal Show. What exactly does that mean?
In the last 20 years I've had no issues, only the occasional scratchy pot which is easily resolved. Are they saying that poor electronics affect the tone in a negative way? Or that the volume and tone pots don't perform as well.
I ask because I have to take the guitar into a tech. Tried to swap out the pickups and made a right balls! Likely cooked it. If this is an upgrade worth doing I may consider it.
Some customers get terribly worked up about this.
As has already been stated, the pickups tend to be a bit bland. Some commentators blame the magnet material.
Can anyone recommend a quality strat wiring kit? (pots, selector switch, wiring etc. Innards!). It's a 'never sell' guitar as sentimental value, so I don't mind spending more for quality.
https://sixstringsupplies.co.uk/collections/prewired-harnesses?gclid=EAIaIQobChMI-o6R_OHrgwMVBJhQBh1x0A6gEAAYASAAEgKaT_D_BwE
A CRL switch will be an upgrade over the original even if the original is an open-frame type (DM-50 or similar) - they're more reliable in the long term, and feel more positive in use. If the original switch is a box type, replace it anyway.
Possibly the best upgrade you can do is to replace the jack with a Switchcraft - obviously it doesn't affect the tone, but they're much more reliable and secure. While you're at it, replace the cable from the jack to the volume pot with a shielded cable, which noticeably reduces noise.
The hunt continues for a quality wiring harness.
