Can anyone help identify the fault with a Alesis q20 rack unit which refuses to turn on .
Was working fine this morning with no issues , then got home plugged it but now no signs of life at all - no hum etc.
Did not hear any bang or anything so not too sure what it is .
I have opened the top to see if there is anything obvious but cant see anything - there is what looks like fuse under the circuit board could this be the issue or maybe the battery ?
https://ibb.co/rm7GPX8https://ibb.co/MPDzpJ6I have tried removing the plastic cover to access the board but the white plastic has what looks like a tag of some sort which runs through the plastic into the board .
any help would be appreciated
Try the fuse and change if blown but if the new one blows then don't try a 2nd as there's obviously a fault which will probably need a tech as these things are a mix of thru and SM components, plus the way they have wired the rear outs make the board a pain to get in and out.
There is a piece of white plastic with a battery change date (2017) on top of the board but has been connected through with some sort of clip so unable to access the screws . Is it Can I swap the fuse with the board in place?
Fuse 2A 250vc 5x20mm F - is this a slow or quick .
From the services manual it says Fuse 2A 250vc 5x20mm F fuse ( is this slow or quick blow?) but says holders so guessing maybe more than one.
If so, and it's not even humming quietly when on, that indicates power not getting to the transformer. If it's not the fuse, that really just leaves a broken connection or a faulty power switch as the other possible causes - unless the transformer itself has died (open circuit - a short would blow the fuse), but that's extremely unlikely.
Since you have a meter, check resistance across the switch contacts in the on position - with the unit unplugged from the wall of course!
Looking at your first pic again, I think that fuse may actually be on the secondary side of the transformer - it's too large a value to be the primary fuse, and the rest of the circuitry around it looks more like a low-voltage supply... I think the bridge rectifier is under the 'QP TST 1' stamp. In which case there may be another fuse, probably closer to the power switch.
https://ibb.co/c60cG29
See that white JTS header on the bottom left. That should have ground, +15V and - 15V for the audio and 5V for the digital ... work back from there because if those voltages aren't present then it's pointless looking at anything else. The fault will be on that PSU
