Hello Chaps,
I'm a noob here on the forum and with respect to playing a 6-string so
I'm hoping to get some advice from more experienced folk about what to
do in the situation I find myself. I think I might want to buy a new amp
of some kind, but I'm an untalented guitarist and not experienced
enough to know how to weigh up the factors involved.
Quick sit-rep:
- I'm a bassist by trade and play in a small trio band and the local
church band. I play a little guitar (badly!) when I have to - e.g. to
fill in some rythym / strumming if that's more helpful than bass on any
given Sunday.
- My daughter is currently learning guitar and flying along with it. I'm doing my best to encourage her.
I have a couple of guitar amps I've picked up over the years - a small
Marshall Practice amp (10W, I think) and a Fender Champion 100.
I don't like the Marshall amp - it's small, nasal and boxy (but I got it for free). It's currently on loan to a friend.
I like the Fender amp very much, but it's far too big for
home practice - we can't turn it up past 2 on either channel before we
risk complaints from the neighbours / blowing the windows out /
deafening ourselves. On the other hand, we've been using it quite
effectively in both of my bands (in church-sized spaces) and all the
relevant guitarists seem to enjoy it. My daughter currently practices on
this one.
I think I'd like to stop carting the Champion around and just leave it
in the church which is far more convenient for both bands' practices.
I think I'd then like buy a smaller practice amp for my daughter and I to use at home.
On that basis, I've been looking at things like
Fender Champion 20 / 40
Fender Mustang LT25
Line 6 Spider V 30
Line 6 Catalyst 60
Questions I can't satisfactorily answer:
I already have a Helix Stomp which I use with both basses and guitars, so do I need to bother with a modelling amp?
Flipped the other way: my daughter isn't capable of using the Helix as
she's still small-ish, so perhaps a modelling amp with presets will
encourage / excite her into making new sounds without the complexity of
creating Helix patches?
I like the whole Helix "ecosystem" so is it better to buy a Line 6 amp
that has some of the Helix FX built in because it'll be familliar?
Or, should I go with the Fender amps because they're cheap, cheerful
and I like them, and, if I went with the Mustang, give me another
implementation of "modelling" for an even wider variety of tones?
The LT25 sounds like a good option:
[+] it's the right size, power- and feature-wise, but
[-] it only has an 8" speaker. Perhaps I'm biased as a bassist but isn't that rather small?
Overall, the Catalyst 60 also seems like a good option:
[+] it has a 12" speaker, which ought to sound better with modelled tones, but
[-] it's hardly any smaller / lighter / less powerful than the Champion 100, but
[+] it does have a half-power switch so I could run it at 30W at home, which sounds a lot more reasonable.
[+] The app that runs it looks simillar to the Helix interface so it would be familliar,
[-] but the FX / etc. on there are straight off the Helix, so
there's nothing "new" - I could probably create an identical Helix patch
for any sound it could make, so I'm essentially paying for a speaker in
a box.
If I were a more experienced guitarist, I could probably give weight to
each of those considerations and come up with an answer, but as a
bassist, it's not my area of expertise. Please could anyone lend some
experience to the questions above?
Many thanks in advance.
Fender Champion 50 has a Celestion speaker and sounds more three-dimensional but a bit more ‘modern’ than the 40.
I understand what you’re saying about an 8” speaker being small. Part of the sound of an electric guitar is a 12” (or less often a 10”) speaker, and I agree that 8” is on the small side.
I’m also a bassist (as well as a guitarist). I’m not actually familiar with those amps other than the Champions, but...
Most important - the power output isn’t a useful guide to volume, 30W is as deafening as 100W in the house - your Champion 100 is almost certainly producing less than 1W with the volume on 2. The only thing that matters is how good the taper on the volume control is.
Speaker size does make a difference - a larger speaker is generally louder and fuller-sounding, although some modern small speakers (and cabinet designs) have a good tone despite their small size. For example the Fender Rumble 25 bass amp sounds far better than the Rumble 15 even though both have 8” speakers - because the 25 has a slightly better speaker and a much bigger cabinet.
Given what you’ve said I would probably ask your daughter! The Catalyst looks the best option for flexibility and familiarity for you, but if she would prefer something smaller and simpler then the Mustang would probably be more familiar to her.
And in my experience, nothing replicates that Fender sound for affordable performance as well as the Fender Mustang Amps.
I have used a Fender Mustang III v1 then v2 100w 12" since they launched live, and even with the weight/size penalty it's still worth it over small speaker options imo.
I still can't find a better value alternative for both home volume or small gig than these. The Mustang GTX aren't cheap but a worthy successor if cost no issue. However, you can pick up pretty mint Mustang III v2 for so cheap these days it's worth it. FUSE software and the 2.2 update are still available from various mirror sites. In main auditoriums, I use as an additional fold back with mic'd speaker or just line out.
By the time you get a good modelling pedal, pedalboard and budget amp etc etc you've hit the GTX100 pricing anyway which includes a brilliant footswitch too.
Great solution for you and your daughter.
[Obi-Wan hand movement] These aren't the amps you're looking for...
https://medias.audiofanzine.com/images/normal/tech-21-trademark-10-1779591.jpg
