It may not be a faulty reverb tank - there's a nasty known fault with the reverb drive circuit on these, fairly rare but serious and can be difficult to fix. I've never actually come across one with it, but someone on here (HHWarner I think) has. Check the tank impedance at both ends before you buy a new one!
Apart from that it doesn't look in bad shape. I wouldn't bother fixing the DI pot, the DI on these is un-emulated and sounds crap.
I'll attempt to source a correct pedal; although in the meantime, is there a way of testing the reverb, or is it a case of if it's turn off then thats tough until its turned on via a footswitch?
To clarify.. the channel footswitch allows the channels to operate independantly and thus toggles clean and dirty.... and has zero relevance on the push-pull pot status?
http://www.ebay.co.uk/itm/Marshall-P803-Twin-Footswitch-/371166144837?pt=LH_DefaultDomain_3&hash=item566b39e945
I think it's also possible the contact in the footswitch jack may stop the reverb working if there's no correct footswitch in it, if it's gone dodgy.
Yes. The push-pull just routes the dirty channel through the clean channel EQ, as well as the single tone knob. (Clue: you always want this .)
Yes, although that will turn your reverb into chorus, and you don't want that.
:-P
