Just taken delivery of a 63 CS strat but it has a tort pickguard and I've always preferred mint green. The last time I changed one of these out it was fairly straight forward as it was on a strat pro ii - so fairly modern. What I've noticed on this CS however is there is a small notch on the pickguard just close to the neck pocket which I assume makes space for the truss rod screw when you need to make adjustments. The modern pickguards don't look to have the same small notch - I'm guessing it would fit but would require the pickguard to be removed when adjusting the truss rod which could be a bit of a ballache? Or will the truss rod be accessible anyway and the notch is just for aesthetics?
• Youtube - https://www.youtube.com/@Goldeneraguitars
Dulling the shine is the quick way to make them look aged, but absolutely not authentic. It can be a good way to make a new part not stand out on a old guitar. Sometimes that is enough, especially with honest restoration.
Repolishing by hand gets much closer to that old shiny look.
It's a difficult balance to achieve.
Instagram
Then you have the fact that a genunely gigged guitar which has been around for sixty years will have been exposed to a lot of cigarette smoke at venues too, so that will make it change colour as well. Just crank up the pickup heights on a ten year old Strat and you see that on the bits of the pickup whch were below the scratchplate look a lot whiter. So those uniform greenish pickguards are more of a fashion thing than an authentic look, although they are probably a good starting point for something which one intends to relic up a lot.
