You can find plenty online… http://acousticir.free.fr/
You don’t have to have one to match your guitar, just the pick-up type
At least that is what works for me.
I find my K&K transducers give the most natural DI sound.
If you aren't familiar with what a convolution reverb does to achieve that, when creating a VST plug in effect which uses that method, a base sound is recorded in a selection of different rooms, then the various different delayed responses of that sound off each surface are mapped. Thus a cathedral setting on a convolution reverb will have been created by literally going to a cathedral, setting up a mike (or mikes for stereo etc), firing off a sound and then mapping the response times off the walls and ceiling etc, to create an audio replica of that room's reverb.
So the response patterns in the various presets which a convolution reverb will have, apply lots of combined (aka convolved) mini reverb effects together to give a more realistic replication of a room. In most convolution reverb VSTs, once you have selected a preset, you can leave it all 'as is' or you can then further tweak the settings if you need to. As with all VSTs, there are some freebies, some inexpensive ones and some super-duper costly ones, which means you can try it out with the free or cheap ones and see if they float your boat, or you can get your big wallet out and spend some more cash to get the fancier ones.
But I'll be trying some acoustic IR profiles on my Kemper next week. If I can get them to sound like this, I'll be happy:
(I suppose something like the Mooer Radar should do the same for fewer £££s.)
I can share the video if you want to show the process
