I've been hankering for a Matchless since I have one on tour in 2005, when I asked for and got a DC30 as a hire amp.
I never got around to getting one, despite coming close a few times, and the DC30 is too loud for me now anyway.
I divested myself of a Diezel VH4 and a Carol Ann OD3R to get it.
I am done with high wattage, high gain channel switching amps for live, at least for a while.
This is a Lightning 15R, which is the 12AX7 channel of the DC30 at half the wattage.
(some would argue the EF86 channel is more fun, but it is bloody noisy too.)
It is still fucking loud though.
I've only had a couple of hours to play with it so far but it is ridiculously good.
I don't like the Strymon Volante with it- the buffer in that pedal make things too bright when the delay kicks in so need to figure out what to do there.
I need to be on my volume and tone pots a lot more too.
I really couldn't be happier.
I didn't get a lot of work done today.
Playing experience is quite different compared to the multi channel amps, but so much fun if you can turn up and control everything from the guitar.
(I don't like EF86s!)
Congrats
Re volante, could you run a buffer before the qmx and then tweak treble to taste on the smp.
The Strymon devices just seem to add sparkle in an amp that already has quite a lot of sparkle.
This was mentioned in a TPS video in Neville Martin's pedalboard build too.
I've only tried one Matchless, but it was exquisite.
https://live.staticflickr.com/65535/53161274749_e53cea39fc_h.jpg
You are not wrong. They are bloody good and bloody loud.
I've been using the Matchless with a Louis Electric Roadrunner and they blend fantastically well together.
The Two Rock must be good too.
Never heard of a roadrunner before… off to Google and YouTube it!
Bandcamp
Spotify, Apple et al
It isn't 'metal' high gain, I don't need that from this amp.
I also sometimes swap in an OCD, Thorpy Gunshot and a few other things.
I've had to change my set up a bit to suit it.
I *think* I'm going to go with the OCD over the Sidecar as my higher gain pedal- it has a bit more body, lower mids and less top end fizz. The KOT is still magic for moderate gain.
I still can't decide between a Klon KTR or a Hudson Broadcast as an always on pedal.
Either are probably fine.
Still futzing about with delay pedals.
Both the Volante and Flight Time add a bit of high end when engaged via the Gigrig QMX, even when in bypass.
The Flight Time is better.
I might have to look at a different delay pedal.
On speakers: I think I just don't like the G12H-75 Creamback with this amp.
Even switching to one in the 1x12 I have here that is completely broken in I find it a bit fizzy and has too much bass.
I've got a bunch of 2x12 cabs here with Celestion Golds, G12M-65 Creambacks, G12-65 Heritage, V30's.
By some measure I prefer the G12M-65's.
They are a bit quieter for what is already a very loud amp, and just seems to suit it better.
So I am thinking of swapping out the Matchless stock G12H-75 Creamback for a G12M-65 Creamback, or maybe even a Greenback.
Oh and I bought a (muchly bargainous) Bad Cat Cub 15r head as a back up amp.
