Vintera 50s modified Strat loaded pickguard - price drop
These came out of my Strat and are essentially brand new. I am not sure if the fancy switching is all present and correct as I think the original selector switch was used on the new setup.
No longer availabe to buy new, I think, as the Vintera range has been changed again. Essentially, the Baja 50s Strat set.
£80.00 Including postage
From the net
Vintera 50s (VINTAGE AND MODIFIED)
From the stats these look like really good pickups and the middle is
RWRP. In a real guitar they totally rock (field tested by me). They work
REALLY well in series wiring.
Edited: 2023.09.06
- Poles: Staggered, Alnico 5
- Middle: RWRP wind
- Loaded Pickguard
- Single Ply 8 hole pickguard with Aged White (almost cream) accessories
- Tone Wiring: Tone1 (Middle/Neck) – Tone 2 (Bridge)
- SKU: 7715998000 (bar code on pickguard)
- DCR 5.8K, 6K, 6.1K from Neck to Bridge
- Inductance: 2.8H, 2.4H, 2.6H
- Real Measurements
- Measured 1: Bridge (6.3k – 2.7H), Middle (6.1K – 2.55H) , Neck (5.7K – 2.34H)
- Measured 2: Bridge (6.5K – 3.15H) 894 , Middle (6.4K – 3H) 933 (or 8), Neck (5.9K – 2.72H) 939
- Measured 3: Bridge (6.1K) – Middle (6K) – Neck (5.6K)
- Measured 4: Bridge(6.1K) – Middle (6K) – Neck (5.8K)
- Red Marks: Red Marks on pole bottoms until around 2021ish
- Numbers on Pickups:
- Bridge: 939-010 (SOUTH)
- Middle: 938-010 RWRP (NORTH)
- Neck: 894 (SOUTH)
- Note: Little ski symbols on the bottom right sometimes, number could be anywhere on the bottom
- Retail Package: Available
- Black bottoms on the pickups, Paper with Wax
- Wire Color: Neck (White), Middle (Yellow), Bridge (White) – Blacks are grounds
From Fender:
- Formvar-coated magnet wire
- Staggered pole pieces for balanced output
- Reverse-wound/reverse-polarity middle pickup to eliminate hum
- Beveled Alnico 5 magnets for more focus and dynamics
- Wound and calibrated for each position
- Vinyl-coated output wire and fiber bobbin
- 5.5K, 5.9K, 6.0K (Neck to Bridge)
- Manufacturers part Number: 0992206000
MODIFIED 50s — ALERT! FENDER FOOBAR —
Watch out for retail packages, The
correct wiring is the WHITE/BLACK wired pickup is the MIDDLE RWRP Pickup
they include the wrong documentation and put the pickups in the package
out of order.
- Pickup changed and S-1 Switch added
- Vintage-Style ’50s Single-Coil Hot Strat® are the pickups installed
- 938 (NECK) South – Yellow wire
- 939 (MIDDLE) North – White wire
- 940 (BRIDGE) South – Red wire
- The basically did what the did on the 60’s, they moved the Vintage
Bridge to Middle and Middle to Neck and added a new Bridge PIckup.
- “roughly” – 6.0K Neck, 6.1k Mid, 6.5K Bridge (Hotter)
- Part Number of Pickguard: 7715999000 (Baja 50s Strat)
- Part Number on a Retail Box: 0992208000 – Made in Mexico
- Incorrect documentation on retail packages.
Save a cow. Eat a vegetarian.
