sadly my self built Stinger [designed by Denis Cornell] combo amp is on the way out. And I think this time it is terminal. For a few months the sound has become 'more wirey' and 'jangly' and this sound cannot be dialed out using the tone controls. The open G, B & e strings just don't sound like they should. I replaced the valves with old but known good valves and this made no difference to the sound.
I built the amp over 20 years ago and have been proud to tell people that I had built it myself. Luckily I have a Pignose to hand so I have something to use. The Pignose is not a good pedal platform, I only use a few drive pedals and a reverb pedal, but at least I get some usable guitar sounds from it.
I am thinking of something in the line of a Katana, not much volume needed but the Katana has a number of useful or potentially useful sounds. If I could get a small solid state power amp [up to 25 watts or so], this could take the place of the Stinger amp electronics and could be used with my POD 2 as a front end. A powered speaker would or could do the same job. All suggestions welcomed, thanks in advance.
Not feeling very happy as I write this.
Nil Satis Nisi Optimum
If you built it yourself, you should be able to fix it. According to the schematic I have, there are seven electrolytics in it, four main filter caps and three cathode bypass caps. It's difficult to be sure, but if I had to guess from your description of the sound I would suspect the power valve cathode bypass cap first - this can often be caused by it being close to the cathode resistor, which gets hot, and heat is the enemy of electrolytics.
I am sure there are techs that would look at it. Cyril Ryan at Audiotronix would have been the guy I would suggest but he is retired now. He might know someone else to have a look.
I still have the schematic for the amp and am willing to replace whatever might need replacing. The Pignose will suffice for my guitar playing until the Stinger is back up and running again.
Aha…
https://www.aggh.net/discussion/index.php?topic=47812.0
…single ended class A with a single preamp stage and a single “make up” stage after the EQ - not a million miles away from my Ampmaker SE5a kit build. There’s not enough there for it to be really broken.
Don’t give up on it.
Even if you end up throwing all the passive components away and rebuilding it from scratch (or throwing a few quid at someone handy with a soldering iron to do it for you) using the original transformers, sockets, pots etc it’s going to be cost effective to fix that...
If that's not it, the second most likely is probably C15, which is the first filter cap and is hit with high voltage and a large inrush current on power-up. This is probably less likely because it's more likely to make the amp hum than sound 'wirey'.
It may simply be sensible to replace all of them - C1, C3, C10, C11, C13, C14 and C15. They're not that expensive.
So don't worry unduly about this, I am not sure if the PAT requirement applies to the Republic of Ireland. It might be, I can ask in an electrical wholesaler when I am next in town.
