GONE: Auden Emily Rose Neo
Here's my Auden Emily Rose Neo, all solid, cedar over mahogany. I bought it used a few months ago, and though I'd love to love it, but alas it is not for me. The biggest issue is the nut width, too narrow. Auden widened the nut from 43mm to 45mm a couple of years ago, this is from pre-nut-width-enlargement. It comes fitted with a fresh set of Newtone Heritage Round Wound Phosphor Bronze 12-51. It also comes with a fitted SKB for Tanglewood case, which so happens that fits it perfectly. No key to the case, though.
In terms of trades I would like a Sigma OMR-21 (with cash my way), which I had a while ago and foolishly moved on. Alternatively, an OM—preferably—or a GA—might consider—with a 1"3/4 nut width and at least 37mm string spacing at the nut. It needs to have a good, robust sound, not boxy or trebly, and warmth.
The specs are as follows:
Top: AA Cedar
Back: African Mahogany
Sides: African Mahogany
Neck: African Mahogany
Joint: Dovetail / Hide Glue
Fingerboard: Rosewood
Head plate: Ebony
Rosette: Rosewood
Detailing: Maple / Ebony
Nut: Bone
Bridge: Ebony
Saddle: Bone / Composite
Pins: Ebony
Machine heads: DJ Vintage 18:1
Finish: Satin
Preamp: Brad Clark Supernatural
Case: Bag
Dimensions
Shoulder width: 240mm
Belly width: 347mm
Waist: 200mm
Depth at neck: 90mm
Depth at Base: 110mm
Full length: 975mm
Scale Length: 632.5mm
Neck width at Nut: 43mm
Neck width at 14th: 57mm
Neck width at 20th: 59mm
Numerous photos can be found here:
https://imgur.com/a/N6gSYZ3I am looking for £650 collected, or I can drop it on my way from Cambridgeshire to the Midlands. I could also post, as I have a box, but you'd need to organise your own courier and I'll pack it better than the specialists, with photos along the way.
A sample of photos below:
Here are the specs as they were on their website on 5 December 2021:
https://web.archive.org/web/20211205052849/https://audenguitars.com/product/neo-emily-rose-full-body/
and here are the specs on 29 June 2022:
https://web.archive.org/web/20220629132603/https://audenguitars.com/product/neo-emily-rose-full-body/
Sometimes between those two dates is when the specs changed.
