The piezo does work. Given the age, relative fragility of the guitar I don't think i'll be trying any mods myself. One for Feline.
I feel the piezo isn't really recreating a true representation of the guitars sound. Its very brittle. Trying to work out what has been installed and whether its worth the time, effort and expense of replacing it with something else that might improve the tone when plugged in.
This is below the neck joint inside the body
If you dont want another box to plug into then a K&K pure mini is good for natural tone or if you want a more electrified tone to run pedals, play slide etc then a mag mic soundhole pickup or LR baggs m80
Have been looking at the LR Baggs Anthem too as well as the K&K pure mini.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I didn’t immediately spot what the guitar was. It’s always a shame when a vintage instrument is butchered like that with a totally inappropriate modern pickup system - it won’t even sound right given the lack of proper depth in the slot, so there’s no point.
Since the endpin has been bored out already you have nothing to lose by fitting a simple passive body transducer which will sound better, as well as allowing the bridge to be repaired properly, and will quite likely make the guitar sound better acoustically too.
Will get the other points raised (bridge/saddle etc) sorted when I get the pickup installed.
It also has the advantage that it will fit some modern Gibsons that the K&K won’t because they have a tooling hole in the middle of the bridgeplate right where the G/D transducer needs to go. Your guitar is much too old for that though.
