The HE4 Piezo cable pickup has a unique construction which avoids hum from by thorough shielding of tips and joints and via an additional carbon shielding layer. The HE4 pickup also features an outer plastic layer which prevents the braid from stretching out or bunching up which also prevents strings from becoming unbalanced after they have been fully fitted.
Warm harmonic tones are added via two FET stages on HE4 pre-amp designs. The pre-amp converts an ultra high impedance signal from Piezo cable pickup to a hot but easily usable output at a cable driving “low impedance” and at around Line Level.
The HE4/G.FEQ pre-amp features a broad shallow mid cut finely tuned for the application plus a small roll off below the fundamental range of the instrument which reduces low end feedback and body handling noise. Each HE4 system utilises interactive “Baxandall” interactive EQ for a more natural and musical response than graphic EQ.
