I'd be surprised if that amp was old enough to have any significant tarnishing, so an electronic solvent cleaner (Servisol do one, should be available at Maplins etc), together with a bit of agitation (inny-outy with the valve).
If that doesn't work, you might have slack pins, or another problem.
Nil Satis Nisi Optimum
The Russians just took pencils with them.
Maplins version of Servisol works fine for me. They do a switch cleaner with lubricant and contact cleaner without. Cheap and works well
Works just as good as Servisol but crucially it smells better
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
The Maplin ‘label remover’ - which is an excellent general purpose strong cleaning solvent - is nice though, it smells of lemon skin.
