I am getting back into recording finally. I have done a bit with my current guitar which is a Lowden 010. I am recording with a single Gefell M300 through a babyface pro fs. I am in fairly decently sized rectangular room with a highish ceiling. I am only using furniture and diy solutions to treat the space. What I do is open up my wardrobe which is full. Lay duvets over the doors a record with the wardrobe behind me while I sit with my back as close as possible. It seems to do a good job of reducing reflections, to my ears the room is generally dampened with a bed in one corner and a thick carpet. Not ideal, I know but just experimenting and trusting my ears.
The 010 has a boomy resonant frequency around 95-100hz. I am typically in open D and when I play a G base note on the 5th fret(low D string) the guitar resonates a lot! It produces a rather heavy woof! When I am just play and not recording its obviously not as pronounce to me. But obviously when recording with headphones, the boom is really hot and the volume spikes around 5 or 6 db.
I know that acoustic guitars all have a resonant frequency. The Mcilroy A25 I used to own didn't seem to have it so pronounce and was generally more balanced.
I can mitigate it by applying some palm pressure just above the bridge area but this is not ideal for ergonomics.
I apply a LC on the EQ and drop about 5db around 95-100hz which cleans things up a fair bit. But that boom still peaks through andI don't want to pull it down so much that it kills that warmth in general. I am trying to practice just it that note more lightly but when I get lost in the moment I just end up hitting it normally.
I have also applied some volume reduction on these hot spots post recording which also helps but I prefer to address it at source to reduce the need to apply multiple clean ups in post.
Any other suggestions or advice for recording and mixing techniques to help tame these resonant spikes?
Have you played the Lowden in the garden so that you can remove the room from the equation? Is the resonant boom still there? Is it the guitar or the room?
Move more to the centre of the room. Also, in a multi instrument mix many reflections are invisible, as being 3 to 6db lower than the main source, are effectively masked. That's better than boominess.
Where is the mic positioned? IMO the starting point for close micing is 3-4in away from the 12th fret and shooting toward the soundhole.
If there is no solution with the above use a multiband compressor around that frequency range.
If all else fails try a dynamic EQ.
Will give this a try
Thanks
The 010 is indeed a big sound and very dynamic! My next idea is to pick up second mic. I'm looking at picking up something like the se electronics VR2 and recording in stereo with the M300. Have the M300 for detail and the Vr2 for the warmth and body and give the guitar a wider space on the stereo image.
Good shout, I have dabbled with mid side recording when I had an se4400a and it sounded good. I sold that mic sadly. I do like the sound of the se VR2 though which sounds smoother and more natural, with that lovely warmth.
You're better off with an omni mic than a ribbon if your source has lots of low end.
I do love the vr ribbons though
Generally for acoustics as a rule of thumb: nice in mono near the 12th or 15th fret or stereo XY/Blumlein 1-2 feet away & from 3 feet and further you might look at a spaced omni pair (and jenklin disc) like they do in classical recordings.
Any thoughts on the line audio omni1 pencil mics?
