Greetings folks,
Apologies for a quite off-topic question, but for those familiar with Osmo PolyX oil, how many coats would you advise?
My project is a rocking chair (Hal Taylor, after Sam Maloof) in sweet chestnut (very similar grain, colour and smell to oak, but not nearly as hard or dense), which clearly isnt a guitar but the principle of finishing in this instance are the same.
Ive applied 5 coats so far, with approx 12hrs between coats and a very light de-nibbing with Abralon 600grit between coats. The coats being applied in a fairly thick manner, left for 5-10 mins and wiped off leaving a thin film to dry.
I'm extremely happy with the satin look and feel so far, and wondered if anything would be gained by adding more?
Cheers,
Adam
Oh, and whilst this isn't a guitar the proceeds (making on comission for some friends) have funded my new Ryder LP. So there is a link
Cheers,
Adam
I've used TruOil in the past, with a slurry technique but using wet n dry paper. But TruOil is a quite different method anyway. I would not be keen to use a wire wool approach on the sweet chestnut for the simple reason it feels quite tannic and I'm not sure how much it would be stained by the iron. Obviously a test run would help, but it would have to be left for some time I think in order to answer that question.
At some point I shall try adding tints to the Osmo, I suspect it would work well for browns, oranges, reds.
Personally, I think it takes 2-3 more weeks to fully gain strength, after which it is as tough as old boots!
The thinner 1101 version, I will generally do 5-6 coats, in the same manner - or with the first couple of coats slurry-and-wiped.
May I ask what grit do you sand the wood to prior to oiling? Osmo recommend 180-240, but I normally go to 400-600. Overkill, perhaps? One thing I have noticed is that PolyX 'covers up' errant scratches from the grit below quite well indeed.
Yes - it's quite forgiving, but I always finish each grade fully 'with the grain' - you do have to get rid of any sanding lines at an angle to the grain as they will, indeed, show.
