Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I would heat it with a soldering iron (a bit of solder helps thermal transfer) to just about the point the wood is about to start smoking, then as it cools down, grab the end with a pair of needle-nose pliers and wind it out - the screw will have expanded and forced the wood back temporarily. If you chew up the wood around it a little getting the pliers in it won't matter.
If you get it out cleanly you may even be able to re-use the thread in the wood without drilling and dowelling it.
If that fails, what FelineGuitars said.
Ian
NB, almost never me who broke the screw! One of the more common ones is straplock button screws, because the strap is held too far from the guitar body and bends the screw sideways. Even though you’ve only got the footprint of the button to cover it, it’s usually possible to get it out with no visible damage afterwards.
This place is definitely worth the entrance fee
@BillDL the body is from guitar build. It's a maple cap t-type with the LP control layout.
Good job getting it out with the heat, tho. Definitely less invasive that way.
