What’s the issue with the intonation? Is it spread out across the neck, or…?
1) The nut is probably cheap plastic and not especially well slotted.
2) The Tune-o-Matic style bridge does not permit sufficient travel of the saddles to adjust correctly.
3) There may be a mismatch between the fingerboard radius and the bridge.
2) Tuneomatic was replaced with one from ABM which has an extended range. The g string currently in there is unwound and the saddle is adjusted as far back as it goes, a changeover to a wound g is on the cards.
3) Don’t think there is a mismatch, both are 12” as far as I know. The guitar was designed by Gordon Smith so I’d be surprised if they had decided to go for a mismatched bridge and radius.
Ignoring the g string (which would likely benefit from a wound string), there is a sourness to chords as you move up the neck which is more pronounced than on a regular scale.
The Earvana should still make a difference though, as it addresses the string flexibility issue - whereby a thicker/less flexible string plays flat when open due to the nut groove constricting it, hence you’ve actually tuned it sharper than you think you have, which makes fretted notes sharp. That will apply just as much, and maybe more, on a short-scale guitar.
I found a wound string of appropriate thickness in my string box and put that on this morning. It is a big improvement.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
