I'm window shopping atm and leaning towards one of the Record Power options given that I can get them (and spares) locally very easily. I'm happy to entertain others though, and I'm curious what size & power etc most of you lot use in your day-to-day... e.g. I can't see myself needing a 14" throat depth anytime soon, but who knows!
*edit* Updated to include your major 'shop machinery of choice, e.g. pillar drills, planers*, etc.
*still not convinced that I actually need one for my purposes and output, a router sled & jig should be ample!
Mine's an Axminster White; equivalent of the current Professional range, which are around the £2k mark.
I've got a roughly 3.5*4.5m area to work within, so it's smaller than I'd like, but still enough to do what I need to do with some careful planning and workflow management. The only things I've bought so far are a couple of bits of extraction that were on offer and that I know will serve my purposes
Definitely bearing guides, not blocks, and Tuffsaw blades.
In my case I wanted a 13” cutting height so that I could cut tree trunks into slabs for body blanks. I also prepare bowl blanks for turning, often working from tree trunks, so wanted a 1.5hp saw, which I think is the most powerful saw I can run on single phase. I looked at the Record Sabre 450, but preferred the Laguna 14BX for its blade guides. Whatever you choose don’t get manufacturer’s blades. Instead look at Tuffsaws.
Like you I don’t have much space, less than 3x4m. My bandsaw, tablesaw, and planer are on 4” locking castors. My pillar drill is floor standing so that it doesn’t take up bench space. It’s top heavy, so wouldn’t be stable on castors.
Tablesaw, planer and lathe were picked up second hand. Jet pillar drill was bought new because the only secondhand ones I could find were bench mounted.
Aye, I've heard that about bearing guides too - seems logical. I'll check out Tuffsaw too, thanks.
@chickenbonejohn - interesting, the 300 was on my list too but there's only ~£130 between that and the 350 but the 350 gets me +40mm cut depth (230mm max), larger table, and heftier motor so that feels like a worthy upgrade to me.
@Roland - this will all mostly be for guitars, but probably with the odd furniture project too. Mostly hardwoods, and right now I'll be surprised if I'm cutting anything deeper than neck & body blanks on the whole, though I might end up resewing some caps etc so I'm allowing for a 7.5/190mm cutting depth at min. to cover off the usual sizes. The Lagunas look great and have a fantastic rep from what I've heard, but are likely over what I'm prepared to spend for my immediate needs... ask me again in a few years! That sounds like an impressively organized layout you have there for such a space - would you mind sharing any pics / sketches of the layout for inspiration please if possible? I'm converting the rear ⅔ of my single-brick garage, so it's pretty much a blank canvas within those outer
I've also got one of those RP air filters/cleaners too for the ceiling, they're a great system and pretty great value really considering how much they help.
