Shite bridge
Jim54Jim54 Frets: 257
I've had this MIJ 62 double bound tele for years and do love how it plays (when it's behaving). However, whenever I change strings (which I've just done after fitting a Lollar 52 bridge pickup), half of the strings are dull sounding as they never seem to sit in the saddle grooves properly, and you have to faff around for ages to get it sounding right. Also never liked the way the strings contact the back of the bridge before they go under the bigsby bar.
Are there any decent replacement bridges that do a better job?
  • SchnozzSchnozz Frets: 1957
    This calls for a caped @ICBM ;
  • robgilmorobgilmo Frets: 3554
    Have you tried cleaning them?
  • floeighty2floeighty2 Frets: 159
    Mastery
  • Jim54Jim54 Frets: 257
    They look worse than they are but it couldn't hurt.
  • DdiggerDdigger Frets: 2377
    Not everyone's cup of tea (and I have no experience with them myself), but Wilkinson do 3 and 4 screw Bigsby mounts with rollers...
    https://wilkinsondirect.com/product/wilkinson-wbtbr-3-bridge/
  • KurtisKurtis Frets: 723
    edited March 5
    It seems like you'd need to make sure the string is sitting in the right groove of the saddles.
    The strings look to be different distances apart in the pic.
    It's the same with a lot of tele bridges tbf. It's a rather 'basic' design, especially with the bigsby pulling the strings back and forward.
    Yeah, the string spacing is a little off, due to having to move the strings about a bit to get an optimal ring from the strings.
    Are the strings also dragging across the back of the bridge?
    If you mean are the strings touching the back of the bridge, then yes.
    normula1 said:
    Possibly, I'll have to look into it.
  • ICBMICBM Frets: 72540
    No idea, the one on my Bigsby Tele was fine, rock-solid and never a problem. I did threadlock the height screws, and I think I shortened the ends of a couple of the intonation screws which otherwise would touch the strings, but I don’t remember for sure.
  • Matt4887Matt4887 Frets: 45
    Mastery
    Agree the Mastery Bridge is the way to go.
    I have the same Japanese 62 custom tele and the stock threaded type saddles are absolute shite.
    Fitted a Mastery bridge about 15 years ago which solved the buzzing, alignment and strings skipping between the grooves whilst playing. Definitely a worthwhile upgrade.
    Thanks everyone, I'll have a read about the mastery bridge.
    Would shimming the neck and raising the saddles help at all?
  • guitarcookie1guitarcookie1 Frets: 464
    Lower the bridge & raise the saddles to compensate?
  • FunkfingersFunkfingers Frets: 14553
    Yes. It would increase the string break angle over the bridge saddles.
    Use nylon washers to keep the bridge perpendicular to the top of the guitar. Mustang saddles to maintain the radius and eliminate the problems of the intonation screws sometimes fouling the strings.
    Yes - I did that on mine, which is why I think I had to shorten the intonation screws. The Jazzmaster/Jaguar/Bigsby Tele bridge always works best with the saddles as high as possible in my experience.
    This is one of the modifications that I inflicted on a Squier VM Mustang before it went to thecolourbox.
    The saddles could do with being thicker.
    I'd be tempted to make some new ones. An old bit of threaded bar isn't very...fancy.
