where's best to buy crybaby mods?
WYNIR0WYNIR0 Frets: 367
edited March 7 in FX
Finally got my GCB-95 back from languishing under my sons bed at his mums for a decade and I'd like to do a LED mod (possibly more if that goes well) . What I can't settle on is where is decent to buy from. I checked Ebay but came up short..
Thanks!
monquixote said:
I agree with WYNIRO much as personally I think he is a total cock.
  • WYNIR0WYNIR0 Frets: 367
    Nobody?  :'(
  • SporkySporky Frets: 28738
    I bought a drop-in board from www.wah-wah.co.uk years ago, but I don't think Stuart does those any more.
    BYOC has one - https://buildyourownclone.com/collections/wah-volume-eq/products/wahdropin
    There are probably others.
  • Switch625Switch625 Frets: 587
    Interested to know this too… pulled out my old crybaby a couple of days ago and want to do a true bypass/LED
    For TB and an LED all you need is a 3PDT, an LED, a bezel for the LED, and a current limiting resistor - maybe 1k as a starting point.
    Thanks Sporks. That would be very useful if I had the faintest idea about these things.but I will see what I can work out.
    That probably reads a bit snarky, not intended to be.
    It doesn't read snarky to me.
    https://wah-wah.co.uk/
    The DIY Resources on the left, and there are details there of the TB mods. You'll have one poke if a 3PDT left, which you can use to switch power to an LED via a 1k resistor (so it doesn't burn our or sear your retinas). Geofex is worth a look too, but can be very technical indeed.
    awesome, thanks Andi
    Parts ordered. What could possibly go wrong!
  • KurtisKurtis Frets: 744
    Makes all the difference imo.
    I didn’t do the led but some small tweaks to resistors and the toe down position just makes it sweet.
    On mine (which had trim pots) I think I upped the gain and the Q slightly, and that was the wah sound I wanted.
    Yeah, I've got one (or maybe two can't remember) trim pots inside. Set and forget.
    Think I changed inductor too, not sure it made a huge difference really.
