There might be something in the power settings I can change, when I'm in the room using it and its dropped below 20% it enters power saving mode but still runs fine. Only when I leave it for over 10 minutes does it shut off with more battery life for some reason.
if the battery shows 0% at start up, then its unlikely to be the settings TBH, Id say the battery was on the way out - what happens if you let the battery charge right up ? (TBH I never dont use the charger at home - never use battery only)
The BMS chip won't allow the cells to drop below 2.8V generally .. if it gets close it will turn the battery off regardless of what the laptop says.
Change the battery but be careful of fakes.
FTFY
It seems that when the laptop hasn't been used for a few weeks, the battery drains, but whatever monitors the battery charge level doesn't update, so when you do turn them on, they show the battery level from when they were last used, but will turn off due to low battery. Once plugged in, the battery level shows as expected.
They are fairly cheap laptops, so I suspect whatever does the battery energy monitoring doesn't use the battery voltage, and isn't active when the laptop is switched off.
HP use a coms pin on their chargers ... it's that little pin dead in the centre of the charger end. Often that gets bent and then all kinds of problems will start but I think if your battery charges then it's just a case of it's worn out and needs replacing.
HP Pavilion 15-CW1507SA - Replacement Laptop Battery 3 Cell (thelaptoppowersupplyshop.co.uk)
Do I need to be paying any attention to the mAh value? Or are they essentially all the same?
There's an HP part number on the battery ... be something like 920070-855 Buy the same one
I'll have a look inside to get the part number.
Is it the HT03XL number or the L11119-855 number?
