I thought this is useful a watch, it breaks down which one are best for sanding down, ease of application and effect.
Could be worthwhile trying to find a replacement headlight unit.
From experience, if it is a vaguely modern car it is easier to swap out a light unit rather than try to change the bulb...
For best results, restore the headlight lenses and then have paint protection film applied. That will stop any UV degradation and stone chips, scratches, etc, and is much more robust than applying clear coat over the lenses.
A good detailer will be able to restore the lenses and apply PPF, had mine done for £60 per headlight - the PPF was laser cut to fit the specific headlight unit of my car and looks better than new. Well worth it IMHO.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Toothpaste : Didn't Work
DWD40 Works for a day or two
Kit: Kind of works , but not 100%
My headlights always pass but with a slight smear !!!!!
Bandcamp
Bandcamp
takes 20-45 minutes to do the pair, depending on the state of the lenses.
Then they will look like new.
Will need doing every year or two unless you apply a suitable protection
It's very easy to overheat the lens and end up smearing plastic around, rather than polish it, so don't concentrate on any one area for more than a couple of seconds especially if using mechanical assistance.
