SOLD Fender Custom Shop Postmodern Strat Journeyman Relic, Josefina Ancho Poblanos - Black
DumodalDumodal Frets: 500
edited March 18 in Guitars £
Selling my Custom Shop Post Modern Stratocaster in excellent condition, this is the Fender concept of a Vintage Strat meets Modern times, it has a compound Neck Radius of 9.5"-12", cutaway access on the neck joint, Oval 60' shape Neck.
The Pickups are Hand-wound and signed by Josefina Campos the legendary Fender pickup maker, the Ancho Poblanos have slightly higher output which gives more beefiness to the sound without losing clarity, the bridge pickup retains more body so it takes overdrives better without sounding nasal.
The guitar comes with everything, COA, an early version of the Shop floor model, cards, picks and Fender cloth.
The finish is Journeyman Relic which has some dings, swirls, and cracking that came from the factory, the body is two pieces of Ash with a weight of around 7.9 lbs bathroom scale. The Strat was recently set up with StringJoy 9-42 with a semi-low action.
It is in basically mint condition, the only thing to report is one of the case latches is a bit wonky, you need to push it and slide it to close it.
I am asking for £2600, not looking for trades, collection from Kingston upon Thames, but I  can post the guitar (need to calculate shipping prices).
Specifications:
Neck Shape: 60's Oval C
Fingerboard Radius: 9.5" To 12" Compound Radius
Fingerboard Material: Round-Laminated Rosewood
Position Inlays: White dots
Side Dots:  White Dots
Number Of Frets: 21
String Nut: Bone
Nut Width: 1.650" (42 Mm)
Nut Material: Bone
Hardware
Bridge: Custom Shop Vintage Synchronized Tremolo
Pickguard: Nitro Tortoise Pickguard
Control Knobs: White
Switch Tip: White
Hardware Finish: Nickel/Chrome
Tuning Machines: Vintage-Style
String Trees: Single Wing With Tall Metal Spacer
Strings: Nickel Plated Steel (.009-.042 Gauges)
Electronics
Bridge Pickup: Custom Shop Hand-Wound  Josefina Campos Ancho Poblanos
Middle Pickup: Custom Shop Hand-Wound Josefina Campos Ancho Poblanos
Neck Pickup: Custom Shop Hand-Wound Josefina Campos Ancho Poblanos
Pickup Configuration: SSS
Controls: Master Volume, Master Tone, 1/2 Blend
Switching: 5-Position Blade: Position 1. Bridge Pickup, Position 2. Bridge And Middle Pickup, Position 3. Middle Pickup, Position 4. Middle And Neck Pickup, Position 5. Neck Pickup
Miscellaneous
Included Accessories: Deluxe Hardshell Case, Cloth And Certificate Of Authenticity
Pictures:
  • DumodalDumodal Frets: 500
    Bump reduced to £2500.
  • fendergibsonfendergibson Frets: 563
    That’s lovely, I wish I hadn’t clicked
    Thank you, hope it goes to a good home!
    Now sold!
