For parallel compression, popular for drums create an aux bus track and send some things to that. This is parallel compression, some of the signal travels through it. So this is just like an aux track with reverb or delay but has a compressor insert on it instead
For master bus compression, stick a compressor on the master bus if you want but generally that's a mastering thing really.
Most of the advice above is worth taking note of. Comp on the master bus is probably not what you’re after: arguably, you’re starting to master rather than mix at that point…you might fix one thing at the expense of something else.
Once you’re done mixing, you can bring up the overall level by putting a limiter on the master bus. Or a combination of comp/eq/limiter…a quick and dirty diy ‘mastering’ approach
I don't think I would agree that putting a compressor on the master bus is necessarily something that should be left to mastering, though. It can certainly be a mix choice and if you're doing more than a dB or two of gain reduction it will change the mix balance so you definitely want to work with it in place from a fairly early stage.
For checking mixes in the car I put a compressor and limiter on the master bus myself
Remove the compressor though if you send it out for mastering as you can't take compression off a 2 track master
As a result I would typically do a few things to glue the bits together which would usually be:
Bussing similar things like guitars, synths or percussion that are doing a similar job and then putting a "glue" compressor or saturator (or tape sim which does both) to stick everything together a bit.
Have a room reverb on a send that I would send a little bit of everything to just so it sounds more like it all exists in the same space (putting on the master with a low mix as Danny suggests would do the same thing)
To do this in Reaper, add an empty track for each bus you wish to create, and make sure they're routed to the Master bus. On each channel you wish to send for bus processing, go to the routing, remove the send to the Master, and add a send to your bus track, post fader and set to 0dB.
When I'm structuring a show file for a live mix, I'll usually have two drum buses - one with all the drum mics that'll get some mild compression to tie things together and catch any big peaks, and a second "crush" bus that just has the close miked kick, snare and toms (no cymbal spot mics or overheads) and gets slammed with heavy compression, which I'll mix in to taste to add weight and sustain. If I've got multiple bass channels, they'll get a group, as will guitars, and then a vocal group too. Compression across these groups will help the individual sources sit together as a cohesive whole. On dense groups or tracks that clash with the vocal, I'll often use a multiband compressor externally keyed from my vocal group, and just dip a couple of dB in the 1-2kHz range when the vocal is active to make a little more space in the mix for vocal clarity too.
You can, as others have said, also add some compression at the master bus if you wish.
The trick is not to overdo it at any stage (unless that sonic result is what you're going for!), but to use each stage of compression with a specific dynamic or tonal purpose in mind. Subtle use at each stage (channel, bus, master) can give you a tight, controlled and cohesive mix without sacrificing dynamic range and the expression in the performances.
