Yeah these PCB brackets are used in quite a few amps on the pots. You can actually buy the bracket as a separate part or you can reuse the old one if the lugs on the new pot are in the right place. Or if the pot bolts against the front panel you can omit it as it won't really move then anyway.
It seems crazy to me that they would have used a linear pot in there in the first place, they should have just used an off/on.loud switch instead. :0)
