Boss power supply barrel jack replacement
Hi folks, I’ve got a couple of boss power supplies, one of which has had the jack severed and the other has gone intermittent at the jack end. I was going to get a couple of new jacks for them but not 100% what will be the best replacement. I’ve seen these https://uk.rs-online.com/web/p/dc-power-connectors/0487858?gb=s but not sure if it’s the right type.
If someone could point me in the right direction,that’d be great!
cheers.
The Swamp City Shakers
  • ICBMICBM Frets: 72415
    Those will work. The internal diameter is the important one - 2.1mm. There are two other sizes, 1.9mm and 2.3mm.
    I would get these though - https://uk.rs-online.com/web/p/dc-power-connectors/7719186 - firstly because there's a cable strain relief, and secondly because the outer shell of the other type is brittle.
  • bandmaster188bandmaster188 Frets: 391
    Cheers ICBM!
  • jasonbone75jasonbone75 Frets: 636
    @bandmaster188 did you order these yet? Just found this in my stash at the office:
    Thanks for that Jason,but ordered some last night.
