A good question. I don't know that I "want" to change it, rather it's the only guitar I've ever had with P90s so don't have experience to know how it compares to others and my experience with Epiphones has often been they benefit from better quality components.
Not as responsive as I'd like, but that might be down to amp. I was playing through a Boss Katana which is fairly responsive, but I have found my Marshall SC20 to be better at that, so I'll need to put the guitar through that amp to get a more definitive answer.
I’ve changed pickups on about half the guitars I own but only because the previous pickups weren’t bringing out the best of what the guitar had to offer. Example would be my Eastman T386, acoustically it was bright, open and lively sounding. Plugged in the stock Kent Armstrong pickups made it sound a bit flat, lifeless and dull. Pickup swap sorted it.
Last year, one of the Alegree website clearance section offerings was almost what I wanted APART from being A5 rather than A2. Its was a quick screwdriver job to change over.
AFAIK, the Epi Pro pickups have A2 bar magnets. The neck pickup could be made brighter by changing to A4 or A5. The bridge pickup could by made grittier by changing to unoriented A5. In your position, I would alter one or the other but not both.
You may be correct to think that the pots are knocking some high end off the stock pickups. It is equally possible that the bridge and/or tailpiece are sucking away treble.
P90s into saturated valve amplification for the win. Always. Roll back the guitar's volume pots for cleaner tones.
500k is the nominal pot value but it is possible to obtain pots of slightly higher or lower values to suit the respective pickup positions. @sixstringsupplies may be able to advise. They even have ready-assembled wiring harnesses.
Lollars, tom Andersons, Fralins, Bare Knuckle, Mojo (UK) and Mojotone (US) are all great options. they will all be upgrades on the Epis - will pretty certainly respond to pick dynamics substantially better BUT they will also change the tone.
if you like what your getting, and are happy with the pick dynamics, you maybe shouldnt swap them. If you ant to play around - then grab some.
Id highly recommend contacting Mojo, cheaper than most (Oil City are another to try) and if you explain what you have, what you like and what yo might like to change they can guide you to the best options.
Asa has been mentioned - swapping magnets can change things too. I do this quite often with Humbuckers actually. I prefer A2s. For P90s I like A3s for lower gain and A5s for higher gain.
