Point of string breakage and diagnosis
jaymenonjaymenon Frets: 835
If my first string broke at this location - and I had taken 2 or 3 winds around the post (even though it is a locking tuner), i’m guessing that would negate a sharp edge on my tuning post, causing the breakage?
Especially since I can see about half an inch worth of string proximal to the point where it enters the hole of the tuner post (second picture).
  • merlinmerlin Frets: 6717
    edited March 25
    Like the B string, your top E string appears to run over the tuning post for a bit before straightening out. So no it doesn't negate a sharp, or rough part of the post. Have a feel.
    Was the string wound going over a part of itself?
  • normula1normula1 Frets: 640
    I only ever get this if I've slackened off and re-tightened several times. Typically happens when I'm messing under the pickguard and need to take the neck off. It's normally a case of when, not if it'll break :)
  • ICBMICBM Frets: 72554
    String crossed over itself? The B is…
    I would always put the absolute minimum possible wind on a locking tuner, unless - often with the G - you really need to increase the break angle at the nut. I pull the string through the tuner until it’s tight before locking.
  • jaymenonjaymenon Frets: 835
    Thanks guys - I find with locking tuners if I put the 'absolute minimum possible wind' (like what ICBM stated), then pretty much invariably it will break when I slacken the string for whatever.
    That never happens with conventional/vintage tuners.
    So I put a couple of winds on, since the locking mechanism is irrelevant to me...
    'Strings crossed over themselves' -  that's a good point, I shall be careful :)
  • SvartmetallSvartmetall Frets: 716
    I always go with 2 winds around before tightening for low E & A strings, and 3 for the rest; it's worked for me for many years now.
  • SteveRobinsonSteveRobinson Frets: 7063
    Elixir strings?
    No Steve - I find that with D'Addario EXL110s...
    If I for example, slacken the strings, take the neck off to get at the pickguard etc, then re-attach neck and tune up again:
    With vintage tuners I can do this multiple times without any problems.
    With locking tuners, the strings tend to break - very often.
    That tendency is less if I have a couple of winds around the post.
  • FelineGuitarsFelineGuitars Frets: 11623
    Locking tuners do not like you to slacken off and refit strings .
    We speak of Sperzel woes in regard to this in the past
    Whilst it could be a burr or a sharp edge on the tuner barrel (which could be smoothed with some abrasive cord (see Mitchells abrasive cord) it could often be where the retaining pin puts a dent in the string  and it becomes a weak point
  • guitars4youguitars4you Frets: 14334
    Both are my gut feeling - Even a sharp edge on the 'exit/entry' of the string post hole or in the hole itself - A quick clean with a small needle file, through the hole and the edge of the hole and a quick clean around the post itself with wet n dry
  • FunkfingersFunkfingers Frets: 14553
    In which case, why have them?
    Regardless of the locking mechanism type, each string is gripped by the application of pressure via a hardened steel surface. This invariably compresses and fatigues the string. (The old PRS "wing collar" machineheads leave two kinks approximately 4mm apart.)
    In attempting to re-tightened old strings, the temptation is to realign the compression/fatigue spot with the locking mechanism. Unfortunately, this invites new compression and fatigue at a slightly different angle to the original locking point, weakening the string exponentially. It is doomed to break.
    I only have locking tuners on my Gretsch. And I use Thomastiks which have never broken in a gig situation. When I restring I don't use the locking tuners and just string as usual.
