Hi all,
my son has been given a Stratocaster. Can you help identify it for me?
I be think it is in tropical turquoise. It has Fender Corona California on the neck plate. 4 screws and a hole between the two bottom screws.
The serial number is on the reverse of the neck by the backplate with ‘crafted in Japan’ :
Serial number R063017
It has a Seymore Duncan hot rail pickup in the bridge.
It has an 11 hole scratch plate.
Two screw trem. With a 6 screw white trem plate on the back.
Do you have any ideas on what year it is, where it was manufactured and how much it may be worth?
I would like to get it set up for him. Maybe change the pickguard to make it look different. What colours work best? Pictures would be good.
Would a dark blue tortoiseshell work, or a anodised goldy copper colour?
I am doing this on my iPhone and don’t seem to be able to upload any pictures.
Thanks
'Less is more' or is it 'more is less?'
it is in need of a good clean as it has basically sat in a bedroom for about 8 years not being played.
If so it will probably not have the pressure plate in the neck for the tilt mechanism (there’s a screw under that little hole in the plate), so don’t try to use that when setting it up.
Photos would definitely help - if you can’t get them to load on here, could you put them in a public folder we can access?
A neck with a decal reading either Made In Japan or Crafted In Japan under the clear coat is definitively Fender Japan.
The two-point vibrato and "Corona" neck anchor plate suggest Mexico more than USA - not least because a modern US neck pocket would probably be wider than the heel of a Japanese vintage style neck.
The Duncan Hot Rails is designed to work with A250k pots.
As for colour scheme suggestions, Tropical Turquoise looks like a halfway house between Daphne Blue and Sonic Blue. Pickguard should be three-ply Parchment, four-ply Aged White Pearlescent or mirror.
https://photos.app.goo.gl/1kWjZEFpA1uprqf57
https://photos.app.goo.gl/51URZAzv9xYPBZ5aA
https://photos.app.goo.gl/XRqctokDWL1VwH5H9
The Corona neckplate and Crafted in Japan neck probably wouldn't have appeared on the same guitar. I do have an old HM Strat from the '80s that had bits of both Japanese and US manufacture but there are not different country markings on the guitar (only Fender U.S.A. on the neckplate).
I would see what the pots are before changing them - if they’re Fender Mexico there’s probably no need.
No but it can be coil split. Chances are that is already wired to permit that. Full output HR is going to massively overpower a vintage style middle pickup.
Two post fulcrum vibrato suggests Player, Classic Player or Vintera Modified series body. The finish colour suggests the latter.
upgrade the tremolo - yes or no
upgrade the nut - yes or no
upgrade the pots - yes or no
Upgrade the jack plate - yes or no
Thanks
Personally I like vintage tuners and wouldn't bother upgrading to locking ones. Vintage style strat necks are designed to have a few winds of string on the tuners to get sufficient break angle over the nut, particularly on the D and G strings, which if you do with locking tuners removes most of the benefit of them being locking in the first place.
I'd just give it a clean and leave it at that if it's all working.
I will do as suggested.
