Gibson 60's Les Paul Re-Issue Custom Shop - R0 - Iced Tea Burst (2012) - £3100
Bought from Sixty Sixty Sounds in London years ago. In Iced Tea Burst finish. Photos: https://imgur.com/a/0dV3cp8
The guitar sounds great, is a sensible weight (4.2 kg) and is all original and no modifications of any type. These models have the slim taper neck as standard as opposed to the R8 and R9. The guitar comes with the original case and COA. Not much more to say....great instrument in excellent condition and everything that you would expect from a Custom Shop Les Paul.
Professionally set up two weeks ago. Luthier report will be provided. Can be posted but I'd rather do local pickup or I can deliver in St. Pancras or London Bridge.
Specs
Body & Hardware:
- Carved figured maple top
- Solid, non-weight relieved mahogany back
- Single-ply cream binding on top
- Nickel hardware
- ABR-1 no-wire bridge & lightweight stop bar tailpiece
- Thin toggle switch washer & jack plate
- Gold Top Hat knobs
- Vintage tulip single-band tuners (quite important, most tuners only have 1 band but these have 2 which we had to have specially made as we no longer do these types).
Neck & Headstock:
- 1-piece mahogany neck w/long neck tenon
- 22 fret rosewood fingerboard
- Aged acrylic trapezoid inlays
- 1960 neck profile
- 24 ¾” scale length, 1-11/16” nut width
- Holly headstock veneer
- LP ‘60 serial number
Electronics:
- BurstBucker 1 (R) and BurstBucker 2 (T), mounted with slotted screws
- CTS pots and bumble bee capacitors
- 2 volume, 2 tone, 3-way selector switch
