Does anyone make a Telecaster swimming pool route body?
rze99rze99 Frets: 2300
Does anyone make a Telecaster swimming pool route body, finished or unfinished? Or have one available? thanks
  • SteveRobinsonSteveRobinson Frets: 7063
    It's easy enough to convert one
  • FunkfingersFunkfingers Frets: 14543
    Fender does TSH routed bodies on some "modern" American models.
    Some MIM "Nashville" models had a square cavity under the pickguard.
    Speaking of which, a replica "Smuggler's Tele" body will already lack most of the wood you want removed.
    Was it @WezV who restored/made a smugglers' Tele?
  • rze99rze99 Frets: 2300
    Yeah a smuggler body would do it.. I'm not a wood worker. I want to put a midboost circuit under the guard s would carve out most of the pick guard area
    Like that and just remove the inner walls
    Yes. Found it.
    https://www.thefretboard.co.uk/discussion/214334/can-anyone-here-do-a-smuggler-mod-to-my-tele
    In the thread @GSPBASSES ; says they do them....
    The Fender Clapton mid boost uses a PCB roughly the size of a credit/debit card.
    The old Seymour Duncan "Prototype EQ" from the Eighties has a PCB half that size.
    The EMG-SPC and -VMC accessories have a PCB only slightly larger than the pot(s) that control them.
    Something that compact could be installed either near the cutaway - like a Gretsch master volume control - or in the Andy Summers position, above the standard control plate.
    @Funkfingers ;
    It is the Fender one.. I already have the electrics ....just need the body
    At this point, my thoughts turn to the white Telecaster, belonging to Frank Zappa and played by Ray White on the "Does Humor Belong In Music?" concert video. This has three pots crammed into the control plate. (Small, hard-wired EMG ones.)
    It should be possible to mount the mid booster pot on the control plate and run long cables to the PCB in the lower smuggling cavity.
    Alternatively, use a roller pot and mount it at the upper edge of the pickguard à la Jazzmaster/Jaguar.
    Yes it's the Active mid boost with concentric tone knob
  • WezVWezV Frets: 16746
    Yeah, I did the smuggler resto and have also done swimming pool routes on teles.
    It's an easy mod to an existing body
