MXR Blue Box, EBS D Phaser
All pedals are in excellent to mint condition with no velcro on the base.
All photos are here-
MXR Blue Box - fuzz octaver - £60
Script reissue 1990's. Excellent condition with box.
Takes your bass note and duplicates it two octaves down with a thick fuzz. Random, unpredictable, totally nuts! Stoner, doom fuzz.
EBS D Phaser - £65
very good condition. Amazing amount of phase sounds within a single pedal. With box and instructions. No longer made, so collectable.
3 different modes of cool phaser effects. 'Short' is the classic phaser effects recognized from the 70's, 'Long' emphasize the effects a bit more, while 'Wide' gives you extreme swirling flanger-like effects.
Hi, Lo and Off decides the resonance of the effect while the two controls change the width and rate.
In addition you can set a lot of parameters inside the box for fine tuning your sound - volume, phase center frequency, phase stages, low pass filter.
Digital Technique-Analog Sound
The pedal is built with highest quality components and uses 24-bit digital processing circuitry for outstanding performance on stage and in the recording studio. While the pedal offer juicy analog sound, the use of digital technique makes it possible to fit in the same compact format that the Black Label Pedals are knowned and praised for.
