Plus one doesn’t have to worry about buffers or temperatures with that one
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
What pedal is a good entry point into the fuzz face world? All the Dunlop models are a bit confusing.
Or take a look on Ebay or Reverb, there are often people handmaking pedals in the UK for very reasonable prices, well under £100 in many instances.
I think the basic difference is that germaniums tend to be warmer/woolier-sounding while silicons tend to be brighter and tighter-sounding, and also a bit higher gain. But hopefully others can help a bit with that. It (presumably) also depends on the gains of the individual transistors in the pedal, too, and how they're matched and biased.
The caveat I give everyone before trying one is you have to have your rig set for the pedal and not the other way around. Fuzz faces you sort of play like an instrument in their own right.
Into a sparkly clean amp they can sound like dog shit.
If you run your amp clean, run the fuzzface into a light overdrive.
If you use a Fender black panel amp, run the fuzzface into a tubescreamer, which adds mids and tames the bass.
I absolutely love it, and find myself using the other drive on my board (a Hot Cake clone) less and less.
1) Turn off any gates, including any lurking in the input block
2) Input impedance set to auto
3) You can't have anything before the fuzz block in your signal chain (so you need guitar - cable - HX and then the fuzz needs to be the first block) which is also necessary to achieve this with a real fuzz too.
With these things done, then the Arbitrator fuzz does it pretty well. The big drawback on the HX Stomp is that the impact of the pedal switched off radically drops the rest of your signal due to the impedance. Real fuzzes do that too but nowhere near as dramatically as the Arbitrator in HX Stomp does. There are workarounds but they're fiddly.
I'll try a few things as well as the legacy fuzz face that I forgot about just in case, but I think it might just have to be something I do without I think as your previous post, probably better for me to try and do it with some boosting and eq
