I would take it to mean they have no tension on the rod. If its' straight like that under string tension it can be an issue. If its not currently on a guitar I would expect it to resolve with tension.
If it is straight with strings but no tension on the rod, sometimes you can do tricks with the fret level to get it set up correctly with tension on the rod.
If its actually broken and the nut is free turning they can often be fixed, it just depends where it has broken to how easy that is.
If its functionally fine, but has a rattle, there are a few easy fixes that can be attempted to solve the rattle, but it doesn't amplify
Instagram
