- Neck thickness is about the same at the nut, but by 12th fret the thin C is definitely slightly thicker.
- The thin C absolutely feels plankier - I'd have guessed it was 12" radius if it weren't for the spec sheet. Not sure exactly why this is the case, but I know there has been some debate/confusion about whether the original 72 Deluxes were 9.5" or 12", so perhaps it's something in the shoulders?
- On my Deluxe, the strings run very close to the edge of the neck - the nut seems to be cut with slightly less clearance from the edge to the two E strings. Don't know how much this is by design or if it's sample variation.
I got mine second hand, and the neck alignment was slightly out, which combined with the nut cutting meant the high E was practically off the board by the 15th fret. Easy fix for my local guitar tech, and it plays great now. I seem to gravitate to it for Smiths style arpeggiated/jangly picking stuff, as the fingerboard feels like a slightly larger, flatter canvas than my other Tele.
