250k pots with bright humbuckers
OK I've got this Les Paul..It is far too Bright..I've had a Seymour Duncan Custom Custom in the Bridge and it is bright..
With a Bare Knuckle Mule in there ouch..So a 47 uf cap in there instead of a 22..At 2 out of 10 on the tone control it is usable with the Mule,,of course there is a perceived volume drop..I could re alter my pickup heights with the tone control on 2...Or try a 4th pickup in there...
I've already had a Burstbucker Pro..Custom Custom and JB..The JB sounded like a very bright JB at least..The other 2 were not very versatile because of brightness..Also mid scooping seemed to be going on,no body to the sound..The Custom Custom is supposed to be mild..It works good in a Semi Solid..
So there are 3 possible solutions..
1 The 250 K Pot for a Tone Control..I don't know how effective this is..
2. Get a pickup wound to tame the top end.
3. From looking at tone charts,reading other peoples experiences and having one a long tome ago..
Put a Dimarzio Super Distortion in the Bridge position..I last had one about 8 years ago in a little Westbury Guitar..
I thought it sounded good..I know it is ceramic and some folk turn their nose up at that..
  • LionAquaLooperLionAquaLooper Frets: 1128
    Try option 1 first.
    Doesn't work? Only then do you buy new pickups.
  • KevSKevS Frets: 492
    Try option 1 first.
    OK..Thanks..
    I forgot to ask..Do I put the 250 K on the volume or tone in a modern wired les paul/as opposed to a 50's wired one..
  • Power_FreakPower_Freak Frets: 199
    You can clip a resistor in parallel with the existing 500k pot to simulate a 250k - saves you replacing the pot entirely. You can do this with both volume and tone pot. The taper will get a little messed up but will give you an idea if it moves you towards where you want to go
    OK..I can only find a treble bleed diagram..I don't know how to do the parallel thing..
    Also what value to use..
    https://www.fralinpickups.com/2018/10/17/using-resistors-in-guitars-101/
    Thank You.
