Hi Folks,
For any users of the Bogner 3534 50 Watt - re the FX loop, in the manual it says
"ON: Series FX loop on/off switch, on when pushed in.
ASSIGN: The FX loop Ch2 & 3 assign switch automatically activates the fx loop when Ch2 or 3 is engaged, the loop will be always off in Chl and the FX on/off switch is no longer active. "
Does this mean you can choose to assign it to CH 2/3 and not Ch 1 (by using the assign switch) OR you can use the on switch as a global switch and the FX loop will be engaged for ALL channels?
At first I read this and thoug "What you can't use the FX loop on the clean channel?"
Please tell me you can use teh FX loop on the clean channel!!
Cheers
Andy
@AndySol - The idea with removing it from Ch1 is to be able to put FX on the front end of a cleanish amp, using something like a G3.
It has a different sound.
