• Thirty types of delay effects, ranging from vintage to standards to originals
• Precision modeling of vintage delay effects such as analog BBD devices and tape echo
• Numerous original types such as Dual Delay and Distortion Delay offer new expressive power
• Stereo Looping can capture up to 28 seconds; multiple variations and types
• Combine Loop and Delay effects simultaneously for exciting performances
• Thirty diverse rewritable preset programs, ready for immediate use
• Delay time is adjustable in 1 ms steps, to a maximum of four seconds
• Easy access to multiple parameters allows the creation of complex effects
• All parameters can be controlled using an expression pedal [optional]
• Sync Mode allows poly-rhythmic effects to be created quickly and easily
• Seamless Program Change feature ensures smooth transitions
• Advanced Bypass function with decay avoids abrupt effect cut-offs
• High-quality 24-bit/48 kHz audio sampling rivals professional equipment
• Diecast metal body stands up to hard use on stage
• Stereo Inputs; Stereo Outputs (all 1/4″)
• Assignable Pedal Control input
