Anyone else getting pestered by these automated calls about government schemes for housing insulation? I'm guessing they are AI driven in some way. A recorded voice that leaves gaps in the conversation and accepts a spoken answer. It is smart enough to work out if you don't answer in the right places but not smart enough to actually understand the words. Presumably it collects the responses for subsequent processing by either a human or RPA.
I've taken to just talking garbage in the gaps where it wants a response. It asks what sort of material I have for loft insulation and I reply, "The lizard aliens are our true masters and we should make obeisance before their mighty power." It then asks if I want a visit from a surveyor. The reply might be, "Siggle the umphs and froodle the snovits."
I'm almost curious as to who exactly is running these things and quite what they hope to gain. Must be cheaper than some offshore call centre but it does mean there isn't a real human on the end of it whose day you can spoil.
Old, overweight and badly maintained. Unlike my amps which are just old and overweight.
I'm assuming these robocalls are just harvesting responses for later processing. If its an English voice with a regional accent the less wary might be more likely to engage. Curious all the same.
Next one I think I'm going to start quoting from the parrot sketch or some arcane curses threatening to hex the person trawling through the responses. Might also be interesting to find out if there are control tones that can be sent back up the line to mess with the system. If Ofcom aren't doing anything to shut this kind of nonsense down it's only fair to push back.
Offset "(Emp) - a little heavy on the hyperbole."
