FS: Swart STR-Tweed 1x12 5w combo
Swart STR-Tweed (£1095)
This is the newest, post 2015 version
A great 5w amp that is perfect for a bedroom/studio setup. The 12" speaker makes it sound a lot bigger than it is. It has a really low noise floor as well. The only reason I'm selling is I don't need breakup/OD tones and recently got a Milkman that is a better fit or my setup (not really comparable amps, but can't afford to keep everything!)
Full album:
https://imgur.com/a/km4GZlJ- 5W CLASS A ~ JUST INSANELY BIG TONE BREAKUP!
- Single-Ended Output - Zero Negative Feedback
- 100% Tube Circuit - GZ34 or 5Y3 Valve Rectifier
- Big Swart Tube Reverb - Foot Switchable (foot pedal included)
- Hot and Clean mode Switch
- Powered by choice of 6V6 or 6L6 (6V6 stock option)
- JJ 12AX7(2) - JJ 12DW7 - EH 6V6GT - JJ GZ34 Rectifier
- Point to Point Hand Wired Circuit
- Cathode Biased (no need to bias)
- Carbon Comp Resistors ~ Mallory Caps
- Cloth Hook-Up Wire
- Hi/Lo Input for High & Low powered Pickups
- Heaters referenced to ground
- Standby Switch for tube warm-up, extending tube life
- All Swart Amplifiers employ Star Grounding
- 4/8 ohm 1/4" Out - Drive other Speaker/Cabinet
- Switchcraft 1/4 inch inputs and output
- CTS Potentiometers
- Custom High Quality USA Built Swart Spec Iron
- Speaker: 12" Mojotone BV-30H ~ 8 ohm
- Finger-Jointed, solid Pine Cab w/ Lacquer Tweed Cover
- Vintage Jewel Lamp ~ Circuit Fuse Protected
- 17" W x 10 3/4" D X 16 3/4" H (w/feet) ~ 29.5
http://swartamps.com/swart_space_tone_reverb-tweed.htmCollection in Newcastle upon Tyne/surrounding area. I also have the original box/packing material, so would consider shipping
