After a few years in the wilderness my new band is Looking a feeling good but as I am in uncharted waters of playing lead/rhythm and singing I’m finding that the usual river dance across the pedal board is one step too far for me plus adjusting my one delay pedal between don’t you forget about me and then uprising etc is also a fookin pain in the arse.
I have tried a few multifx over the years on previous bands but as I was only playing guitar they just seemed like too much effort to set up patches and the like, but having seen our bassist and his little HX stomp fly between octave bass for sledgehammer to muses bass sound in uprising, I’m thinking I have to possibly go down this route and just suck it up with the programming part of it
What I would really like is any vocalist/guitarists to tell me what they are using and how they use it and whether it makes life easy from the point of view of going from performance to performance.
Id likely keep my drive pedal but for all the other sounds, it needs to be stuff I can simply click and it’s there ready to go
I know I’m a bit behind the times with this but it seems to matter now whereas it never used to!!
thanks
People get into the idea that they need to have 4 patches for every single song.
I used to gig with a multi FX with 4 patches total.
It's really nice to be able to set up that the delay comes on when you hit your lead boost etc.
You can also have very similar sounds on each patch, you don't need to go nuts, or just don't use patches at all and stick within a scene and use a bit of automation so multiple pedals change at once.
I'm personally running a Boss ES-5, with three drives and one MFX (half an H90) before the preamp and the other half of the H90 after it. I'm using MIDI from the ES-5 to load presets on the H90 and one of the drives (a Kernom Ridge). I sing most of the songs, am the only guitarist (we're a trio) and just don't have time to tap dance any more.
I'd also suggest trying an HX FX if you're sticking with your amp, but I think the MS-3 is a better bet unless you actually intend to start using more exotic effects than the ones you already own.
Replicate what you have now but with the changes on one switch.
I used a Helix when I was gigging. I wasn’t singing (well, just backing) but I also ran the PA, so the Helix was great as it was plug and play and had all the sounds I needed.
I’ve also in the past used a Gigrig switcher with 10 pedals, which also worked well, but was a lot more to carry as I needed an amp as well as the (large, heavy) pedal board.
HTH.
Eqd Speaker Cranker clone
I know - like “what’s the best overdrive?”
Lets be honest, that'll cover just about everything you'll ever do. Setup up patches on the DD500/Mobius. You'll have a patxh with Tremolo/Chorus, and maybe one with flanger/chorus or tremolo or something else. In my covers band I cover everything with that combo.. You can turn the drives on/off as you need. You're a driive nut so even if you do get a multi effects you'll still have a bunch of drives hanging off the end of it..
Multi effects wise. The easiest is actually the Boss GX100 which I'm selling. easy to program and sounds good. Doesn't sound as good as DD500/Mobius/drives but its not far off.
I gigged an HX effects in one band for about a year. It was ok, but I was constantly tweaking .and never really happy with it. The snapshots never seemed to quite work in a band situation for me anyway. I've had a HX stomp which was a nightmare for me in a band situation, not enough buttons and too much to remember. Also had a fractal FX8 which sounded amazing at home and shit in a band situation, and the Boss GT1000 (full fat and core) (great sounding, and the routing was fantastic, but a bit of a mare to setup sounds. Also had various other multi effects over the years. Genuinely the GX100 is the easiest to use/setup and is nearly there but as I said it's not quite as good as individual pedals.
when I was asked to do a solo, I used to just turn up, and kept the same tone from start to finish
(I used to use a Joyo American and a reverb pedal, And then just turn the reverb right up on Wicked Game during the encore )
the gt1000 is more flexible with outputs, multiple effects loop but it’s harder to use.
I still think the main driver here is whether you want song specific settings, such as delay tempo. If you’re happy with one long and one short delay (until someone decides to put something else on the setlist) then just get a second delay pedal.
On the MS-3 you can get 8 sounds per bank (the patch and a CURNUM assignment) so I tend to use buttons 1-4 as verse, chorus, solo & "other". I can change the entire sound with one push if I want to. If you want to use it in "pedalboard" mode, each patch can give five sounds and the switch can act like a single pedal.
I'll try and explain what I do - as I seem to have found something that works for me, and it might work for you, @Travisthedog I'm the guitarist/singer in an originals-only trio, singing most of the songs and have very little time "off mic" to look down and pick a specific footswitch to change my sounds.
We play 10-20 songs per gig (depending on the slot/time available). and none of us are trying to replicate well-known sounds from well-known songs.
In performance, I've got two presets per song defined on the ES-5. One is my main sound for the song and the other usually a solo sound. We pick the setlist in advance and I order the presets on the ES-5 so everything flows in sequence.
Because the ES-5 has 5 footswitches and is organised into banks, I load the presets for the first song into FS1 and FS2 of the first bank. I load song 2 into FS3/4 and then song 3 into FS1/2 of the next bank, etc. FS5 (on the bottom right of the switcher) is used to change presets and nothing else. In the preset loaded in FS1, it selects the next preset (which is the FS2 solo sound). In the preset loaded in FS2 (the solo sound) it selects the previous preset (the main sound).
So, playing the song, I don't need to look down because the only footswitch I use in mid song is FS5. I also set the ES-5 up so switches activate on release, not on press, so I can find the switch early, press-and-hold, then release exactly on time to change presets. Before that, I used a similar approach but used an external footswitch (a Boss FS-6) where one button selected the next preset and the other the previous one. That could be defined on a global basis (which was easier to program) but took up floor space I often didn't have onstage and i needed to know which button I wanted to press every time.
When the song is finished, I either press FS3 to load the preset for the next song or press the "Next bank" switch and then FS1 to select the preset in FS1.
I don't actually have that many sounds. Lots of my presets are identical - a clean amp with nothing on the H90 and a tiny bit of hair in the tone from a drive pedal that I set and forget, just open the loop it's on when I want that tone. But I don't try and remember what tone I use for what song when I'm actually performing - I just set up multiple copies of that combination in the order that they need to be in. I'll just name them "Songtitle V" for the verse preset and "Songtitle S" for the solo preset.
If I need to change a sound at the venue (maybe something gets lost in the band mix in that room), I change the effects pedal settings but never need to change the switcher presets. If my clean sound needs a bit more mids from the mild overdrive pedal, that's where I'll change things, just the once, and every preset using it will pick that up.
Hope this helps. The HX FX or the MS-3 can both support my approach - I just prefer to have external effects (with MIDI, where possible) rather than the built-in ones on the unit. I owned an HX FX for 18 months and it was OK but not inspiring. I'm very happy with what I have now and suspect you'd be fine with the MS-3 or an HX FX if your workflow is likely to be similar to mine.
As an aside - if you play in the sort of covers band where you change the set order mid-gig, then scrabbling around to find the next song is difficult on any switcher where you predefine the setlist. There are iPad apps for managing lyrics and chords, etc. which will send MIDI when you select the song. I know some people will scroll through their iPad, tap on the song and it send MIDI to the switcher to load the correct presets. It's one more thing to go wrong and/or take with you, obv., but it's quicker and looks better than scrabbling on the floor to find your next sound.
I use a line6 HX fx as the core but in stomp mode. Flange, chorus, comp, drive, echo and boost. I supplement with a crybaby, two low gain drives and a boss tremolo. I also have a Behringer fuzz tucked on the corner but tend to stack drives.
