I leave you here a video where you can hear what a guitar with a side sound hole sounds like. It is an accessory that is not yet widespread but that I consider to be a great success.
Whenever I see how someone reacts when they play a guitar with a side soundhole for the first time, I confirm this.
At approximately the 50th second, the mouth on the side opens and you can see the difference. It is always better to listen to it with good speakers or good headphones. I hope you like it.
I assume this one is magnetic, with some damping material between the 2 pieces of wood to stop rattles, or that it's a tight fit
...than it would be, had it been placed at the more common spot - at the junction of the neck with the body at the 14th fret.
