Well…I’m putting a band together for my sisters wedding at the end of June and recently-ish picked up a Valeton GP200 when it was on offer, and then got a Headrush 108 off a friend who was selling it for a great price. I’m finding both units pretty frustrating to be honest, though I suspect it’s mostly down to the fact they are both ‘budget’ units and I should have just bought something better!
The Valeton seemed ok out of the box, however, the more I use it, the more I see its limitations (why can’t I rename a bloody block on the screen??!!!!), the sounds are ok but it’s generally a bit of a faff to use, having had a Helix in the past. The drives just seem a bit ‘meh’ and just getting one patch with a bunch of pedals to turn on and off for a covers band is cheesing me off. Maybe it’s because I was used to the Helix and this isn’t as intuitive. It’s just not at all inspiring, though my needs are pretty limited…a nice clean sound, some crunch, and solo setting, with some nice reverb/ delay and the odd modulation (which I could even probably do without for this one).
The Headrush, as most people know, is a budget FRFR and it’s just ‘ok’. The thing is very bass-y, even raised up a little with those frequencies tricky to completely dial out. I’ve tried cutting some highs and lows on the global settings on the GP200 but it’s still just a bit crap.
Baring in mind I am on a budget, and currently only doing 1 gig (though my old band has mentioned the possibility of some dep work)…should I just stick with these and keep trying to make them sound acceptable, or sell them on and get a Pod Go and some other FRFR?
Or is it just the never ending merry go round of GAS?!
For home practice and setting up presets, I use headphones and you might have more joy with that.
I also thought of a couple of other options to rule out what's irking you with your tone:
- When you owned the Helix, did you get HX Native? You could run a Helix preset you know you like through the Headrush to test it.
- If you have a guitar amp&cab/combo with an FX loop, you could run the Valeton into that (think the FX loop - I've seen that mentioned, but check beforehand, I've not done it myself) and see if it's sounds better.
Native…I did actually…didn’t think of that…will have a look at that.
I don’t have any amps now unfortunately…I sold pretty much everything when I started my business at the beginning of last year. This is also why funds are tight!
Thanks for the suggestions…much appreciated!
https://www.facebook.com/groups/ValetonUsers
And there's nothing at all wrong with the Headrush FRFR108. My Tonelab SE/LE and Pod Go units sound great through them, as did the GP200. These are fine units and I gig with them. You need to get them off the ground though - I mount them on poles. whilst I have two, these are so loud I've only ever needed one out to the audience although sometimes I'll use one as a monitor cab too. If you can't get a good sound, sorry but I'm afraid it's you not the GP200 or FRFR108
These are a couple of live clips from a recent gig with my TLLE:
https://www.terralec.co.uk/speaker_stands/short_speaker_stand_with_35mm_top_pole_max_height_97cm/21444_p.html
