Slight longer answer...
What happens when you push down on the trem arm is you're pulling against the springs with whatever force is required to shorten the strings a fixed amount such that the string tension reduces by X%. Let's call that distance Ym. That distance is dependent only on the strings, the tuning, and the physical dimensions of the guitar (scale length and total string length) - the springs are irrelevant to that equation.
Each spring requires a fixed amount of force to stretch it by Ymm - let's call that Z. If you have 3 springs you need to move all of them by Ymm, so the total force needed is 3Z. If you reduce the number of springs to 2, you only need to exert 2Z of force to stretch the springs by the same amount and produce the same dip in string tension.
I'm simplifying a bit as there's all sorts of extra maths around leverage and moments because it's all moving around a pivot point, but that should all net out to be irrelevant in the context of this question.
It actually works the other way in case of up-bends; more springs will make an upward dive easier, but noone ever really does those so you don't notice.
https://en.wikipedia.org/wiki/Hooke's_law
Hooke's law is only a first-order linear approximation to the real response of springs and other elastic bodies to applied forces. It must eventually fail once the forces exceed some limit, since no material can be compressed beyond a certain minimum size, or stretched beyond a maximum size, without some permanent deformation or change of state. Many materials will noticeably deviate from Hooke's law well before those elastic limits are reached.
So they are linear up to the point they fail or are about to fail
they are approximately linear up to a point quite a bit before failure at which point their stress-strain curve becomes more curved than linear, many materials 50%.
they key is to strain materials well below their failure stress/load to ensure (a) “small” deflections, and (b) no plastic permanent deformation on removal of load.
Fortunately, one of my best friends is a Professor of Mechanical engineering, and I asked him about this a few hours ago.
It seems as if the reason is as follows, based on his advice to me, and my understanding:
The springs used are extension springs.
They are pre-tensioned.
Therefore, for the first part of the stretch, it takes more force to stretch them per mm say, later on it becomes easier - less force to extend by each mm - a more normal linear response.
As mentioned by others, the strings have their own relationship to Hooke's law - at the same length, they should be at the same tension. They don't care what pulls them.
So I assume that, using 5 springs, hardly stretched at all, means that a lot of force is needed to deflect the bridge enough to decrease the length and tension of the strings (which is my usual use of the trem).
Whereas with 2 springs, the springs require less force to stretch them, hence less force to decrease the length of the strings.
